I had contacted support with the same list of questions. I would appreciate if anyone can answer these questions before them because support is closed during the weekend. I want to do some edits to my site http://dearborndivorcelawyer.com/ 1- I want to remove the area where it says "Search" and "Location" fields and the "Search Listing" button. How can I do that? Please give me the navigation/ instructions on how to do it myself. 2- On the home page I want to change the size of the image in the Premium Featured listings. How can I do that? I want only 1 Premium Featured Listing instead of 4. Please give me the navigation/ instructions on how to do it myself. I want it to look something like what you have in the screenshot that I added in the attachment. 3- What is the color hex code of the blue color that is near the logo? 4- Can you customize code to change the design and give it in a way that I can apply to multiple sites that I will be building? 5- How can I update/ download to the latest geo craft version 2.0.5. In the latest plugin you were talking about using adsense and adding Banner ad. I want to use it. Is there a way to change the size of the banner ad? 6- Is it possible to remove the Premium Featured Listings altogether and add a huge banner instead. Is it possible to add 2 banners side by side? Appreciate your help. Thanks SA
Hi, SA.. Greetings from InkThemes! Solutions to your above issues are accordingly... 1) I want to remove the area where it says "Search" and "Location" fields and the "Search Listing" button. Please paste the code given below in Custom CSS field (Appearance -> GeoCraft Setting ->Theme Options -> Styling Options -> Custom CSS) of your dashboard. Code: .main_search { display: none; } .header_wrapper { background: none; } 2) On the home page I want to change the size of the image in the Premium Featured listings. Sorry but I am a little bit confuse with your requirement.. Could you please explain it a bit more so that I can better assist you? 3) What is the color hex code of the blue color that is near the logo? Color hex code is #13b4e3 4) Can you customize code to change the design and give it in a way that I can apply to multiple sites that I will be building? Sure...!! Let me know the changes you want so that we can assist you accordingly (if possible).. 5) How can I update/ download to the latest geo craft version 2.0.5. In the latest plugin you were talking about using adsense and adding Banner ad. I want to use it. You can easily upgrade theme by following all the steps as mention in the below link.. https://www.inkthemes.com/community/threads/geocraft-theme-v-2-0-8-is-available.18853/ 6) Is it possible to remove the Premium Featured Listings altogether and add a huge banner instead. Is it possible to add 2 banners side by side? It requires a lot of customization of source code and our time as well, As InkThemes has been receiving a high volume of support requests therefore, we will charge you for this customization, Do let me know if you agree then, I will tell you the amount and mode of payment. Looking forward to your reply. Thanks & Regards! Priyanka InkThemes.com
