I'm trying to figure out how to effectively use Travelogist Pro. I tried at your documentation page (https://www.inkthemes.com/documentation/), but don't see anything there, and looked in the forum and don't see it there either. Is there a similar theme I should be looking at instead, or how do I find the details for customizing? A few specific things in the meantime: 1. Is there any easy way to eliminate the bread crumbs navigation below the menu bar on every page? 2. I don't need those four widget footer areas. How do I eliminate them? If I go to Customizing -> Widgets, it looks like nothing is set there, so don't see a way to eliminate it. 3. I've got a copyright notice in a footer. It does show up, but it seems like it's constrained to some block or grid area. (See attached screen shot.) How do I get it to just flow across the entire width of the footer? If you can point me to some good documentation, I might be able to figure out more of these things. (I've got decent knowledge of HTML and CSS, but don't have much experience working with WordPress themes.)
Hello, Warm Wishes From InkThemes, 1. Is there any easy way to eliminate the bread crumbs navigation below the menu bar on every page? To make the desired changes, just paste the code in the Additional CSS section of the theme. Go to (Dashboard -> Appearance -> Customize -> Additional CSS). Code: .page_heading_container { display: none; } 2. I don't need those four widget footer areas. How do I eliminate them? If I go to Customizing -> Widgets, it looks like nothing is set there, so don't see a way to eliminate it. Kindly refer the below attached video link this will help you to customize the widget area of the theme. https://www.screenpresso.com/=fEp5g Or to completely hide the widget area, To make the desired changes, just paste the code in the Additional CSS section of the theme. Go to (Dashboard -> Appearance -> Customize -> Additional CSS). Code: .footer_container { display: none; } 3. I've got a copyright notice in a footer. It does show up, but it seems like it's constrained to some block or grid area. (See attached screen shot.) How do I get it to just flow across the entire width of the footer? So you do not want the social icons to show up? Or you just want the copyright section placed in between? Let us know the above details and send the below-mentioned credential details at [email protected] along with the thread link. WordPress Website URL: - WordPress Username: - WordPress Password: - We will do the needful for you. And you refer the black rider theme documentation as it is this theme is the customized version of the black rider theme. Kindly find the PDF file of the documentation in your member's area account. Regards, Shemaela InkThemes.com
Sorry, I'm having trouble finding the documentation for the theme. If I look at page https://www.inkthemes.com/documentation/, it lists BlackWell, but not Black Rider. They're not the same, are they? And I looked at my account page (I assume that's what you mean by "member's area account"), but all I see there that's useful is the link for downloading the Travelogist theme (which I obviously did previously). Can you give me a direct link to the PDF? Thanks.
Hello, Warm Wishes From InkThemes, Kindly login to your member's area accounts you will find the PDF of the black rider theme's documentation. We have added the PDF of the documentation in your account. And you can refer the black rider theme documentation as this theme is the customized version of the black rider theme. Regards, Shemaela InkThemes.com
Good -- that helped a lot, and I'm making progress. Now I need help in tweaking my blogs page (see attached screenshot or http://tomgut5.dreamhosters.com/russs-blog/). I want a much simpler page, so I guess a need to know some class selectors that I can set to not display. Specifically, I don't want the following: * the block that shows the Colorway Lite form * the block that has four columns, each with a 170x166 something -- * the heading "Our Latest Blogs" -- is there a way I can put in my own text? If it requires you logging in to my account to change code, just give me the CSS to eliminate it. Thanks, Tom
Hello, Warm Wishes From InkThemes, Would you please share with me the URL of the website. I will then let you know the settings to be done on the blog page accordingly. Regards, Shemaela InkThemes.com
http://tomgut5.dreamhosters.com/russs-blog/ is the specific page I'm asking about. http://tomgut5.dreamhosters.com/ is the home page for the site.
Hello, Warm Wishes From InkThemes, It looks like you have not made the settings of the theme properly. If you do not mind kindly send the below-mentioned credential details at [email protected] along with the thread link. WordPress Website URL: - WordPress Username: - WordPress Password: - We will let you know the needful about all the settings and we will make the settings for you. Regards, Shemaela InkThemes.com
You should have received my email with the wp-admin credentials. In the meantime, a few more questions: 1. I created a slider from the theme options, but it's applying the slider to the posts page (http://tomgut5.dreamhosters.com/russs-blog/), whereas I need the slider on the front page instead. (http://tomgut5.dreamhosters.com/). Is there an easy way to do that, or should I just use another slider plugin for the home page? 2. I've got a couple links on the home page (near the bottom of the rightmost column), but they don't show any highlighting. I know how to do CSS styling for a:link, so can you give me the class name for those links? 3. On every page (except the blog page with the slider), the name of the page is repeated, as a large heading, just below the menu bar. Is there any way to suppress this? 4. (This is a repeat of an earlier question.) How can I get my copyright notice in the footer to use the full width instead of wrapping around? Thanks, Tom
Hello, Warm Wishes From InkThemes, 1. I created a slider from the theme options, but it's applying the slider to the posts page (http://tomgut5.dreamhosters.com/russs-blog/), whereas I need the slider on the front page instead. (http://tomgut5.dreamhosters.com/). Is there an easy way to do that, or should I just use another slider plugin for the home page? Actually you have not set the home page and the theme settings properly, So we have done those settings for you. Kindly now have a look at the home page of your website it will now reflect the changes you will make in the theme options panel. 2. I've got a couple links on the home page (near the bottom of the rightmost column), but they don't show any highlighting. I know how to do CSS styling for a:link, so can you give me the class name for those links? Let me know the links about which you are talking, I will then provide you with the CSS code. Kindly share the screenshot along with the above information. 3. On every page (except the blog page with the slider), the name of the page is repeated, as a large heading, just below the menu bar. Is there any way to suppress this? To make the desired changes, just paste the code in the Additional CSS section of the theme. Go to (Dashboard->Appearance->Customize->Additional CSS). Code: h1.page-title-gall { display: none; } 4. (This is a repeat of an earlier question.) How can I get my copyright notice in the footer to use the full width instead of wrapping around? We have made the settings for you kindly have a look at it. Regards, Shemaela InkThemes.com
(Please also refer to my email message from yesterday.) Thank for you for your help correcting my settings. But your changes caused the Customize > Additional CSS option to disappear and be replaced with CSS/HTML Editor. See attached screenshot. Can you restore the original option so that I can make the other changes you described above? Thanks much, Tom
Hello, Warm Wishes From InkThemes, I would like to inform you that our technical team has replied to you via Email. Kindly once check your Email and in case of further queries you can follow up with us via our Email. Our technical will surely answer the queries you have got. (Please also refer to my email message from yesterday.) Thank for you for your help correcting my settings. But your changes caused the Customize > Additional CSS option to disappear and be replaced with CSS/HTML Editor. See attached screenshot. Can you restore the original option so that I can make the other changes you described above? The Additional CSS section comes from the Customizer panel and the CSS/HTML is the default editor from Wordpress. And we have also got the theme's editor which you will find in the theme. Have a look at the screenshots and the video link attached. https://www.screenpresso.com/=0J3Eb I hope the above details will surely help you. Regards, Shemaela InkThemes.com
