Need Help With Videocraft
Discussion in 'VideoCraft WordPress Theme' started by anthonyherring, Feb 2, 2017.
  1. anthonyherring
    anthonyherring New Member
    Recently purchased the VideoCraft theme and I have a few problems.
    1. When it comes to the video search box, the sign-up, sign in and contact page the font inside the text box is too light and is hard to see. How can I change the text to a black color?
    2. When a person signs up on the sign-up page they can put the wrong email address inside the text box and can still sign up. How can I do an email check from the text box or something that tells the subscriber that they entered the wrong email address?
    3. Finally, I need something that will show the subscriber that their sign up was successful.
  2. Naveen
    1) We can provide you the required custom CSS code to change the color of the fonts, just share your site URL here so that we can check and share appropriate codes wit you.
    2) The theme uses default WordPress registration mechanism, and you want email verification kind of feature in that, which is not so easy as it may require lots of customization in the source code of the theme and if you want us to do for you then. there would be some charges.
    3) Can you share a reference, As the theme used default registration process it won't appear after successful registration, this may require source code customization in the theme.
    Warm Regards!
    Naveen Kolhe
  3. anthonyherring
    My website is www.imsodmv.com
    The comments/reply text box fonts are too light as well.
  4. anthonyherring
    Who do I talk to about customization?
  5. Naveen
    Here are the required custom CSS code for query #1
    .searchform input[type="text"],
    #loginform .signinForm input[type="text"],
    #loginform .signinForm input[type="password"],
    #reg_form input[type="text"],
    #reg_form input[type="password"],
    #reg_form input[type="email"],
    #contactForm input[type="text"],
    #contactForm textarea{
    color:#101010;
    All you need to do is just paste the above custom CSS code in Dahshboard->Appearance->Theme Options->Styling settings->Custom CSS field.
    This will help you to figure it out and resolve the issue(s).
    Warm Regards!
    Naveen Kolhe
  6. anthonyherring
    Thank you
  7. Naveen
    You are most welcome :)
