In the red box: I need to place 5 images under the phrase "Partner Brands" instead of text, how can I do this In the Cyan Box: How do I change the icons so that I can have custom or other images In the Blue Box: I need to add 3 Images that go nowhere, but are important Please help with these, if you need to get into the site let me know
Hello, You can edit the contents and relevant icons from the theme options panel, please refer the theme documentation. You will be figure this out. However, adding the images and required changes to the those areas are concerned, it will require some source code customization. We can do it for you. Warm Regards! Naveen Kolhe InkThemes.com
Kindly, share your WordPress admin credentials at [email protected] along with this thread URL: WordPress site login URL: WordPress admin username: WordPress admin password: I will check and do the needful. Warm Regards! Naveen Kolhe InkThemes.com
