Hey, I've put some commission junction ad banners in the theme ad banner section, but it doesn't seem to take any java or even shortcodes... I've tried using bannersnack, Jssor Slider, and a few other plugins but none of the rotator solutions seem to show up. I can put html for one banner at a time, but that's pretty limiting. Thanks! The site is http://www.herbrevival.com
Hello, I would like to suggest you to use "Simple HTML Slider" plugin.. Here is link of the plugin, please have a look.. https://wordpress.org/plugins/simple-html-slider/ Hope it will resolve your issue Do let me know if you need more assistance, Thanks & Regards! Priyanka InkThemes.com
Well that would work if I could put shortcodes into the ink theme appearance menu. Those should be a little more versatile. I can only put html code in there and Simple HTML Slider gives you 2 codes a shortcode and a php code. Neither of these work in your advertising box inserts. So, needless to say it didn't help. I was thinking about just buying the Simple HTML Slider Pro, thinking maybe when I upgrade they will give me other options to insert the slider... but, I didn't. Any more ideas? Thanks!
