Next Page/Navigation not working
Discussion in 'GeoCraft WordPress Theme' started by comedyclubhouse, May 9, 2013.
  1. comedyclubhouse
    comedyclubhouse Member
    When i goto the bottom of my site the pages do not work, it shows in url however it just refreshes the site, even if i click next page 2, arrow to next page or even click to skip to last page.
    Now this is very important indeed as people can not see the other posts, so lets get this sorted ASAP
    URL - http://www.comedyclubhouse.co.uk
    i can't believe how many issues you are getting with all your themes :(
    We have visited your website the problem is occurring due to any one of the plugin you are using, Deactivate all plugins one by one and checkout which plugin creating this problem.
  3. comedyclubhouse
    your themes i have noticed (looking through the forums) has so many issues with plugins :( how is someone to build a site when we get stopped all the time with plugins issues, i'm getting sick of it all
    And NO, i have gone through all plugins and there is an ISSUE and looking through the forums again thats all i see is plugins this plugins that all the time, I have already tested it with all plugins deactivated and yet again tried it now and still an issue.
    ** And I always test all themes with plugins deactivated before posting on forums **
  4. Nitesh
    Blog post pagination are working fine at our side so please provide the following information listed below.
    Thread Link:
    Your Website URL:
    WordPress Username:
    WordPress Password:
    We will check and resolve your issue
  5. comedyclubhouse
    Right again I have deactivated all plugins and still nothing this is getting a big issue for mysite and i want this sorted asap, the if you did look at my site you would have seen that the url sticks on http://www.comedyclubhouse.co.uk/page/2/ as you see the /page/2/ I will leave plugins off for 1hour from this time as i need to work on the site later, so please have a look asap.
  6. comedyclubhouse
    come on Support I got things to do and waiting around is NOT one of them, I'll give you another 30mins to look at issue after that i goto activate all plugins and get on with my work, and i did see that 2 Supports have been online, can you test out your themes before you put them up for sale and not let customers to have to go through all this issues and some are so simple and others i can say not your problem.
  7. comedyclubhouse
    SUPPORT, Please this is very important I NEED for people to click to next page for them to see other events
  8. rogerb
    rogerb Active Member
    Well, I looked at your site and it does have some problems!
    However, what have you done for your front page as it doesn't show recent listings. Was this done by using a plug-in, different configuration of front page or what?
    The pagination certainly has a problem, I notice that there is nothing in your footer is this intentional or is it a side effect indicating some other issue?
    My site uses recent listings and so has no pagination but the show "all listings" works ok with the pagination calling up the listings properly.
  9. comedyclubhouse
    Q- However, what have you done for your front page as it doesn't show recent listings. Was this done by using a plug-in, different configuration of front page or what?
    A- I just went to Settings > Reading > Front Page Displays > Front Page > I Selected Comedy Events (blog page)
    Q- The pagination certainly has a problem, I notice that there is nothing in your footer is this intentional or is it a side effect indicating some other issue?
    A- I don't want/need to add anything on footer, just site name & the social media links, Why ask this Rogerb ? only asking i never been asked that before
    Q- My site uses recent listings and so has no pagination but the show "all listings" works ok with the pagination calling up the listings properly.
    A- As you see I have made Blog as landing page and got listings as separate pages what works great and all page/navigation work great with them as you said.
    The main issue as you have seen is the landing blog page and it's page/navigation it just sticks on /page/2/, I always try every time without any plugins active and still same :( I have not edited any code. Hope this answers your questions Rogerb :)
  10. comedyclubhouse
    SUPPORT!
    OK I have noticed that if i have the blog as landing page the page/navigation does not work, Can you fix it that it does because i wish to use it that way I rather my blog be landing page so first thing people see is the events.
    for now i have had to change it back to other way so people can use page/navigation and i don't wish to have it like this for long, so can you pull your finger out and help please..
    Now I have found out the problem so can you give me a code or something to sort this ASAP
  11. rogerb
    Ah . . thats the reason I asked as I had problems when I tried something similar! Also had a widget issue which completely stopped the footers from appearing.
    Hopefully support are listening as I noticed that the post count for this theme is approaching 950 - not all complaints I hope!
    Roger B
    comedyclubhouse likes this.
  12. comedyclubhouse
    Ah glad you said rogerb I'll keep eye on that one ;) I hope support can help I'm sure it will only be a simple bit of code, but I wish they would test their themes before selling them, I Will agree they do test them but with all these simple issues I have seen in the forums it's like us customers are the test subject for them and I'm not happy for me being a test subject, this is my personal view.
    Juls
  13. Piyush
  14. comedyclubhouse
    right I have sent info via email and i don't see why you need these really as you should know the answer of this code issue but I'll wait and see and PLEASE hurry up i have waited long enough already.
  15. comedyclubhouse
    SUPPORT!
    Please stop wasting my time. My site is on hold now so have look at the issue. I sent reply to email now lets sort this issue ASAP
  16. comedyclubhouse
    5 days later..............
  17. comedyclubhouse
    OK for everybody to know this issue has been sorted :) I will post the codes and info tomorrow just incase anybody gets the same issue ;)
