No AvailableAppointments
Discussion in 'InkAppointment WordPress Plugin' started by bookworm, Nov 19, 2015.
  1. bookworm
    bookworm New Member
    Hi
    I have set up ink Appointment as instructed in the PDF and added the available days of the week and available time slots
    but when I try to test the form on the front end of the website It won't show any appointment times just displays "Not Available" in the time slot field
    URL: http://garysschoolofmotoring.co.uk/book-your-next-lesson/
    any ideas
  2. nitin
    nitin Guest
    It seems that you are not following the proper steps to add time slots in the plugin.
    No need to worry, for you I have made a video tutorial representing how to add time slots properly. Please follow the video link given below: -
    http://screenpresso.com/=U8ume
    Hope this helps...!
    Nitin
  3. bookworm
    bookworm New Member
    Hi Nitin
    I had set it up correctly in the same way as you demonstrated in your instruction video
    After some more testing I think I have found the issue why is not working! - It doesn't play nice with either / both Themify flow theme or their builder plugin.
    So it could be a query conflict
    additionally could please let me have a copy of the version which supports the UK date format dd/mm/yyyy
    thanking you in advance
    yours
    Ian
    Hello Ian,
    You would be glad to know that we are working over this implementation and going to be released in our next update soon.
    We will notify you soon regarding this.
    Your patience will be appreciated.
  5. bookworm
    bookworm New Member
    Which issue will that update hopefully address, the incompatabilty with themify flow / themify builder or the uk date format?
    thanks
    Ian
  6. priya
    Hello Ian,
    My intention was towards the UK date format that will be implemented in the next update.
  7. bookworm
    bookworm New Member
    Thank you I will look forward to that
  8. priya
    Thanks for your patience...
  9. girljocks
    girljocks New Member
    I am also having this same issue. I'm using Thrive Themes and am using one of their stock themes without the builder.
    I set up the Dates and Times and receive a Not Available in the time slots.
    I tried looking up that video you posted above, but the link is no longer available.
    Help please
    Robin
  10. priya
    You are suggested to reinstall a fresh copy of the plugin and check after that..
  11. kcmnls
    kcmnls New Member
    Is it possible to put up that link to setting up the appointments again.
    Thanks in advance.
  12. nitin
    nitin Guest
    I would like to let you know that you are provided the PDF file in your member's area account.
    You will see the file named as InkappointmentDocs.pdf in your member's area for download. It contains all the necessary instructions for setting up the appointments.
    Incase, you need any further assistance just let us know on [email protected].
    We would be glad to help.
    Nitin
