No links to posts working
Discussion in 'RoadFighter WordPress Theme' started by carlgt_web, Feb 27, 2014.
  1. carlgt_web
    carlgt_web New Member
    I just added a few test posts to a site for a client and have discovered that none of the links to any post from anywhere in the site (default sidebar included!) work. Every link ends up in a "Page Not Found" error. Even the "View Post" button on the dashboard leads to the "Page Not Found".
    I've a good look at the settings and can't see anything obvious, any idea what the cause of this could be?
    Cheers
    Carl
    I think you have added wrong permalink structure in the Dashboard > Settings > permalink.
    Set it to default or postname and then check post link. It will work.
    If not then please share your website link.
    Nitesh Raghuwanshi
  3. carlgt_web
    Ha ha!
    Yes, Thanks Nitesh for your quick reply. You're absolutely spot on. I realised that I'd made that mistake about an hour after posting. Amazing what a bit of time away from your computer does for your brain!
    Thanks again
    Carl
