Hi The title should read "Not rendering correctly". I'm using Black Rider theme. I have a plugin that allows you to send the same post to numerous destinations at the same time. All works very well until you view a sample post of what was sent. For some reason, it only renders the top section/masthead (where the logo and orange call to action are). Is there a fix for this? I look forward to replies. Thank you. Kind Regards Graeme
Hello, Thanks for contacting us, We have to check the plugin is compatible with our theme or not. Kindly send the below-mentioned credential details at [email protected] along with the thread link and also share some edited screenshots of the concerned areas of your site. So that we can deliver you an exact and appropriate solution to you, WordPress Website URL: - WordPress Username: - WordPress Password: - We will do the needful. Regards, Akbar InkThemes.com
