No side bar in blog posts
Discussion in 'BlogsTrend WordPress Theme' started by daria369, May 25, 2013.
  1. daria369
    daria369 Member
    I have the same issue as someone else before me. In the single blog post, the side bar with widgets is displayed underneath the post/body - instead of being on the side. The good thing is that that only happens in Chrome, while Firefox seems to display everything properly.
    After reading all the responses I disabled all the plugins but that has not made any difference. Is there anything else I could do?
    My website is:
    http://dariasworld.info/
    Thanks in advance,
    Daria
    We have checked your website and there is no problem with the sidebar in the single page. If you still having the problem then send us the screenshot.
  3. daria369
    daria369 Member
    Here are the screenshots:
    1. Home page in Chrome (does not display the ad banner next to the logo)
    2. Home page in Firefox (for comparison)
    3. Single post in Chrome (no banner on top and no sidebar - it displays underneath the post)
  4. Nitesh
    I have checked your site on Google chrome but not found such issue.
    Please check your site on another system. It maybe a browser plugin issue.
    Check image for reference.
  5. ikarooes
    ikarooes Member
    Dear Daria369, we have the same problem, the sidebar disappear inside the post.
    How do you resolve finally?
    Fran.
  6. internetmarketingsmarts
    internetmarketingsmarts Guest
    Try logging out. I had the same issue in Google chrome. But once I logged out, the sidebar appeared on the right as it should. It's a weird bug.
  7. Nitesh
    Thank's internetmarketingsmarts for this clue.
    We have generated problem at our end.
    We are working on it and will resolve it as soon as possible.
  8. Nitesh
    Hello All,
    Please download theme again from your members area and upload it.
    It will resolve this issue.
