No Slider text on mobile devices
Discussion in 'Compass WordPress Theme' started by computerpros, Jun 15, 2016.
  1. computerpros
    computerpros Member
    Has the Compass theme been updated yet to allow the slider text to work when using a mobile device?
    I would like to inform you that we usually disable the description area from the mobile view due to responsiveness issue..
    But if you want we can do it for you..
  3. computerpros
    computerpros Member
    What problems does this cause to have it enabled for the mobile devices? The site looks odd on the mobile device without the text.
    Actually, on mobile site, the text will become so small that users are unable to read out the text and all the description will look messy..
    but still, if you want to add the description for small devices let me know I will do it for you..
    Hope you will understand..
  5. computerpros
    computerpros Member
    If it is not too much of a problem, I would like to try it and see how it looks on my site.
  6. priya
    Alright..
    Please send me your site URL..
  7. computerpros
    computerpros Member
    computer-pros.net
  8. computerpros
    computerpros Member
    email me back, and I will send you the username
  9. priya
    Please use below code..
    @media only screen and (max-width: 767px){
    .salesdetails {
        display: block;
