Hi, Here is a thing. I tried to do my own custom language file, based on your tutorial. But there something wrong and it's some deeper problem i think. Firstly, in tutorial there is a point that you have to put your translation in "language" folder. But, there are two folders in wordpress directory. One in wp-content named "languages" with standard language files translations AND "theme" folder where i did found translations for standard themes. Default.pot on which on I had to do a translations was in different folder named "language" in theme directory, and here is a thing. In tutorial, there wasn't clarified for which one folder I had to put my translations, because from tutorial it's not so obvious. I tried to analize which one is write, but, here is another problem. If Colorway there would use language file from "languages" (that suggest code line in inkthemes-functions.php) , theme should be, at last a half-translated, because some of words from standard translations appear in Colorway theme. But it isn't translated at all. It also didn't find my translation in "language" folder; didn't find translations I added to original translation file; didn't find file in /languages/themes even I named it like in tutorial and also like another files in there (in same schame). It didn't find it even I changed /languages to /language in inktheme-functions.php . Of course wordpress menu and other standard themes works fine with standard translation for my language. Any ideas what I could miss in this case? Thanks,
Hello, If you want to translate the theme in one language then follow the link given below http://www.inkthemes.com/how-to-cre...-of-wordpress-theme-in-multiple-languages/02/ If you want to translate the theme in multiple language then you can achieve this through 1. qTranslate plugin, See the link for reference http://www.inkthemes.com/how-to-translate-your-wordpress-website-using-qtranslate-plugin/01/ Or 2. Google Language Translator plugin, See the link for reference http://www.inkthemes.com/make-multi-language-website-by-using-google-language-translator-plugin/08/ I hope this will help you. Thanks & Regards Gourav Shrivastava
Sorry, but no, it will not. Because I wrote in my first post that I already tried to use your tutorial and it didn't help. I also write why it didn't help.
