I am using WordPress : 4.7.2 Theme : Traffica Pro 1.1.6 Plugin : Column Shortcodes 0.6.9 I am not able to get 3 columns to working
Hi, Greetings from InkThemes, I would like to let you know that you are running on a very old version of the theme, whereas the latest version of the theme available in member's area is Traffica v1.2.1 Kindly upgrade your theme to the latest version available. It will resolve your issue(s). Thanks & Regards! Nitin InkThemes.com
Hi Nitin Thanks for the news. I have updated my theme to v1.2.1 But i am still getting difficulties somewhere. see attached sample code and the result. one thing i have noted is if i opt for 3 columns, the last column is put on the next line. if i opt for 4 columns, the last column is put on the next line. the attachment explains. Regards Adam
Hi, I got your concern. To determine and fix the issue, we need access to your dashboard. So, send us your website WordPress login details at [email protected] along with the thread link. Your Website URL: WordPress Username: Password : We will check the things from our end and will let you know what's missing. Thanks & Regards! Nitin InkThemes.com
