I looked at my site on two different browsers this morning and it is only showing the mobile version, how do I get it to show desktop? http://www.medicaresupplementsavingsnetwork.com/
Hello ! Which theme you are using ? I am not getting our themes on above website. Thanks & Regards Pramod
Which would be the problem. Dzonia Wordpress Theme v2.3.6 The one on the right is what is showing in the browser and the one on the left is what should be showing. The left is from dashboard.
Hello User, Could you please send us some edited screenshots of your issues so that we can have a detailed look over your issues and will try to resolve them as soon as possible. Thanks & Regards! Naveen Kolhe InkThemes.com
Hello Imarmes! I have checked you website and it works perfectly you can also see it in below link. http://screenpresso.com/=nhPvc Image is missing which you provide in above messages . Thanks & Regards Pramod
I am having a similar issue. It appears to be mostly in IE 9. Compatibility mode 'helps' but doesn't fix it.
Hi, I have checked at my end its working fine. I have attached the screen shot for your reference. Kindly retry at your end. It should work. Regards, Sameer
