Was told that a plugin I want to install is being block by theme creator, how can it be unblocked so that it can be install?
Hello, We have not blocked any wp plugin with the Geocraft theme. Please do let me know which plugin you are trying to install.
Go to the wordpress admin menu and click on The “Offline Plugins” tab and then “QR Code Generator” The plugin will then be activated, and the shortcode options will be available on the same page. I could not locate the wordpress admin menu so I contacted hostgator for assistance and they informed that the (offline) plugin was being blocked.
Hello, Please check this plugin with WordPress default theme "Twenty Ten". It is showing same results with default theme also.
I wish you would offer a little more details. I'm not completely sure I understand what you're saying.
Hello, I think there is some problem with the plugin. Please check "QR code generator" plugin with WordPress default theme "Twenty Ten or Twenty eleven" it is behaving same with them too.
