The images that you have in the sample site look great and load great too but I can't get my images to view properly. What are the image sizes needed and best format to use to both visually and also to optimize load time?
For optimizing images, Images should not be extra larger. If your images are larger than the expected ratio, your images will loading slowly and if your images have smaller size, then your images will load quickly in your site. The theme requires optimized size of images is maximum 444pxwidth or 270pxheight.
