My website is theme1.1stopnonprofitshop.com I'm having an issue with image loading speed. All images were sized and saved for web in photoshop. My banner image slowly loads for the first time and then 4 featured sections pop up at different times...some loading quicker than others. I found a plugin that does extra imaging optimization...but only for photos in the media library. When you add photos to the homepage, you are uploading them directly from your computer...not the media library. How do I fix this? I was told to try to update my site to the newest version...but that didn't help.
Hello, Greetings from InkThemes! As you have said that your plugin only works for the media library... So if you want you can easily add your slider image from the media as well and for that you just need to copy paste the image URL from the media library to your slider/feature image boxes as I mentioned in the video given below.. Link to the video: http://screenpresso.com/=uJjkf Hope it will resolve your issue Do let me know if you need more assistance, Thanks & Regards! Priyanka InkThemes.com
