Padding Above Footer
Discussion in 'Dzonia WordPress Theme' started by 1stopnonprofitshop, Nov 15, 2016.
  1. 1stopnonprofitshop
    1stopnonprofitshop Guest
    How do you add padding above footer?
    theme3.1stopnonprofitshop.com
  2. nitin
    nitin Guest
    To add the padding, please paste the code given below in Custom CSS section
    .footer_wrapper .footer {
        padding-top: 40px;
    Note:- The above value for the padding is the one that is presently set in your theme, please change the value accordingly
    Hope this helps...!
    Nitin
  3. 1stopnonprofitshop
    That didn't make any changes.
  4. nitin
    nitin Guest
    This time try the above CSS itself with the 'important' parameter as shown below:-
        padding-top: 40px !important;
    Incase, the above code doesn't work, just send us access to your dashboard.
    Send us your website WordPress login details at [email protected] along with the thread link.
    Your Website URL:
    WordPress Username:
    Password :
    We will do it for you.
    Nitin
  5. 1stopnonprofitshop
    This code didn't work either.
