I am trying to use this theme to work with WooCommerce... Typically, I am able to do this by duplicating the page.php file from the theme, and renaming it woocommerce.php - then I just need to replace the theme loop with the woocommerce loop. I'm trying to do this using the instructions here: http://docs.woothemes.com/document/third-party-custom-theme-compatibility/ The problem I'm having is that in the Woodpecker theme's page.php file, I don't see an endif (just an endwhile)... The code for the loop in my page.php file looks like: Code: <?php if (have_posts()) while (have_posts()) : the_post(); ?> <div class="page-heading clear"> <h1><?php the_title(); ?></h1> </div> <div class="page-content clear"> <?php the_content(); ?> </div> </div> <?php endwhile; ?> <!----------------------Page Ends --------------------------> ... I only see the endwhile; and no endif; If I replace the code above with the woocommerce code, it completely breaks my shopping pages (they are a blank white screen)... I've used this process before with no problems, it's usually as simple as replacing the loop - the problem I'm having here is that it looks like the loop as coded in the woodpecker page.php file isn't entirely replaceable? Thanks...
Never mind - looks like it was a disk space issue on my server... I upped my disk space and everything worked...
Now the problem I'm having is that the sidebar is stacking below the store contents... My store displays within the theme correctly now, but I don't know why it would be pushing the sidebar underneath the main page content?
I figured it out... it looks like there was an extra </div> inside of your page.php loop... I added the </div> after the woo commerce code: Code: <?php woocommerce_content(); ?> </div> ...that fixed the problem, and the page layout looks correct now.
