I have checked my web site for errors on Screaming Frog and there are a number of Connection Timed out errors. Also I have looked at the Google Page Speed which is very slow and only scores 39/100. I think I know what the problem is but I do not have enough experience to make the necessary changes. I am using version 3.2.2 of the Colourway theme and need to load the latest version, however changes have been made to the website both by my old web designer and with help from Ink Themes staff in the past. I do not know how to make a child theme or what to do with it, I think this is the correct way to make the changes. The website is www.thedogsclub.com Any help would be much appreciated. Thank you
Hello, Greetings from InkThemes! To resolve your issue, I would like to suggest you to use "Better WordPress Minify" plugin in your dashboard as it allows you to combine and minify your CSS and JS files to improve page load time. And also set standard size of all the images as mentioned in Theme Options panel of the dashboard (Appearance=>Theme Option). Here, I am providing you link of the "Better WordPress Minify" plugin, please have a look: https://wordpress.org/plugins/bwp-minify/ Hope it will resolve your issue Do let me know if you need more assistance, Thanks & Regards! Priyanka InkThemes.com
