Pages issue
Discussion in 'Poloray WordPress Theme' started by astermedia, Jan 10, 2017.
  1. astermedia
    astermedia Member
    The Netherlands
    Hi there,
    Certain pages in a client's website need editing. Soms of the pages show no content in the visual area where they do in the text area. They can't be changed. Others seem normal. Also, when content is given to a new page, the same thing happens, nothing remains in the visual area.
    What can be done to fix this?
    Please advise.
    Steven
  2. Naveen
    Hi Steven,
    I am afraid to say that, I was unable to locate the area in the theme...
    It would be better for us to understand your query with the help of edited screenshot.
    Naveen Kolhe
  3. astermedia
    astermedia Member
    The Netherlands
    Hi Naveen,
    Please allow me to try explaining it with the attached 2 screenprints. Scrprt 9 shows the content in text mode. Scrprt 10 should give a wysiwyg visual of that content in the visual area but instead it shows a blank page. My client normally works in the the visual area to make up his pages. Some pages have this problem, others do not. If you wish I can send the credentials to support ?
    Best wishes,
    Steven
  4. nitin
    nitin Guest
    Hope you are doing good...!
    It seems some of your plugins are conflicting, kindly deactivate all your plugins for once and then check if it solves the issue.
    If you still remain with the issue, just send us your website WordPress login details at [email protected] along with the thread link.
    Your Website URL:
    WordPress Username:
    Password :
    We will fix the issue(s) for you.
    Nitin
  5. astermedia
    astermedia Member
    The Netherlands
    Done! :) 2 contact form plugins were in conflict with each other!
    Thanks so much,
    Steven
    smith likes this.
  6. Naveen
    That sounds great :)
