How do I remove the "Pages" section listed on the right sidebar? I see where you can add widgets to the sidebar, but "Pages" is not listed, so therefore I can't remove it. theme1.1stopnonprofitshop.com
Hello, I have removed that section from your site.. Kindly check your site.. Thanks & Regards! Priyanka InkThemes.com
How were you able to remove it? Also, do you know why the thumbnail images are getting cut off on some of the pictures? Do they need to be a certain size in order to not get cut off?
Hello, I have removed text widget from your secondary widget area of your dashboard.. Regarding another issue, I have checked your issue and would like to tell you that there is no any issue as of cut off in your site because your actual image is like that... Kindly recheck your site.. Thanks & Regards! Priyanka InkThemes.com
