Pages showing in two places
Discussion in 'GeoCraft WordPress Theme' started by climbclassifieds, Sep 9, 2015.
  1. climbclassifieds
    climbclassifieds Member
    Please can you help, how do you amend pages showing in two areas ?
    Best Wishes
    Sorry, we didn't get your issue...
    So could you explain a bit more with some edited screenshot of that area and please make us clear what you exactly want and also provide us URL of your site so that we can better assist you?
    Inkthemes.com
  3. climbclassifieds
    Hello Priya,
    The dashboard page for the customers accounts has disappeared, so made another page with template dashboard. This is now showing on the menu bar and I wish it not to and want to be able to click the top right hand corner for dashboard and for it to appear but says 404.
    Can you help fix this please?
    Thank You
    Could you please provide us your Dashboard credentials at [email protected] so that we can have a look over the issue and able to resolve in your Dashboard?
    Inkthemes.com
  5. climbclassifieds
    Dear Priyanke,
    You have my details for another enquiry, I will talk to Nitin about this last unresolved issue
    Best Wishes
  6. priya
    Ok! thanks for the information. We will check your issue with the provided credentials earlier and surely resolve your issue.
    Inkthemes.com
