Pagination Missing :/
Discussion in 'ClassiCraft WordPress Theme' started by gjspinney, Sep 24, 2016.
  1. gjspinney
    gjspinney New Member
    Canada Eh!
    Okay, pagination, page 1, 2, 3, and so on is missing on my site..
    Is there a button to set this active that I am missing or something.. :/
    Image below is of your website..
  2. gjspinney
    Canada Eh!
    Okay, figured out some of it...
    If you put it on static page, then the pagination shows up..
    But it does not show up when I select the radio button "Your latest posts"
    Which defeats the purpose of having a dynamic website.. :(
  3. priya
    Yes, you are right..
    Pagination will show only on the blog page, not on front page..
    So if you use blog page as front page, pagination will show over there..
