Paragraph Issues
Discussion in 'Compass WordPress Theme' started by crystal0811, Mar 16, 2017.
  1. crystal0811
    crystal0811 Guest
    Lately we have been having troubles with paragraphs on some of the pages. They aren't formatting properly. For example; if you go to http://cyndistrid.com/red-chair-project/ you will see a bunch of text with no clear paragraphs. On the backend of this page, under visual, it shows 9 paragraphs. When you go to text, it shows no <p> </p>.
    This has happened to a couple of pages recently and I don't know why. I even went in and added <p> </p> to every paragraph manually and it didn't last long before it went back to having issues. All plugins are up to date.
    I really need to get this fixed for my client asap. Also, can you recommend a plugin for adding <p> </p> and other basic coding, so I don't have to add <p> </p> manually if this happens again in the future.
  2. nitin
    nitin Guest
    We tried visiting your website but it displays an error message as "Internal Server Error". You can have a look at the attached screenshot.
    Kindly bring your site live so that we could determine and could assist on your issue ASAP.
    Nitin
  3. crystal0811
    crystal0811 Guest
  4. Naveen
    Hello Crystal,
    I have checked the links but didn't get any content in <p></p> tag, could you please allow us to check your site.
    It seems there could be some cache issue.
    Naveen
  5. crystal0811
    crystal0811 Guest
    Sure. Where do I send our login info to?
  6. nitin
    nitin Guest
    Just send us your website WordPress login details at [email protected] along with the thread link.
    Your Website URL:
    WordPress Username:
    Password :
    We will check everything from our end and will let you know what's missing.
    Nitin
  7. crystal0811
    crystal0811 Guest
    I just sent it over. I am hoping we can get this resolved today. Thanks for your help.
  8. crystal0811
    crystal0811 Guest
    Hi. I set my login info yesterday. Are you able to help fix this issue?
  9. Naveen
    We have replied to your email, please check.
    We didn't get your issues, kindly share some screenshots for the same.
    Warm Regards!
    Naveen Kolhe
