I'm having trouble getting the password protect function in WP to work. Are there any known conflicts between this theme and WP that would interfere with the password function?
Hello, Greetings from InkThemes! It seems that you are looking forward to setting password protection for your content.. So let me tell you that there is nothing conflicting between theme and WP as you stated above, you can easily set it through your WordPress.. Please follow the screenshot given below. Hope you will find it helpful... Do let me know if you need more assistance, Thanks & Regards! Priyanka InkThemes.com
Thank you. I have set the password protect function in WP, but it does not work correctly. The protected page will not open. I didn't know if anyone else with this theme had experienced similar problems. I will check to see if there is a conflict with any of the plug-ins I am using. Perhaps the problem lies there.
Hello, Yes, it might be possible that some of your plugins are conflicting with the functionality... So it would be better to deactivate all your plugin and check after that.. Hope it will resolve your issue Do let me know if you need more assistance, Thanks & Regards! Priyanka InkThemes.com
