Password Recovery - How to fix
Discussion in 'GeoCraft WordPress Theme' started by kentoliver, May 1, 2013.
  1. kentoliver
    kentoliver Active Member
    "The e-mail could not be sent.
    Possible reason: your host may have disabled the mail() function..."
    How do I go about enabling the password recovery.
    Thanks again!
  2. Neeraj
    Neeraj Administrator
    Hello Kent, The password recovery email is default wordpress functionality the theme does not have any roles to play in that. The error you are seeing can be becasue of disabled php mail extension. I would recommend you to contact your host they can provide you with some solution for this issue.
  3. kentoliver
    Thanks for this Neeraj!
