Password reset function issue
Discussion in 'VideoCraft WordPress Theme' started by ahoque, Aug 31, 2014.
  1. ahoque
    ahoque Guest
    Hello, my password reset function does not work. When I click the reset new password button, I get a email to a link to change my password. When I click the link, it takes me to a sign in page but never give me a option to change it.
    Note: I already sent email to support about a week ago with no response yet. Kindly assist. :)
  2. ahoque
    ahoque Guest
    website is nasheeds.tv
  3. Yogesh
    Yogesh Guest
    Your issue have been fixed in latest version of theme that is videocraft 1.2.4.
    Download it from members area and reinstall it.
    That will resolve your issue.
    Yogesh Bhade
  4. ahoque
    ahoque Guest
    Thank you Yogesh. How do I replace the W logo image on the password reset page with my own site's logo?
  5. Yogesh
    Yogesh Guest
    Add following code at last in function.php file and set path for your logo image.
    function custom_loginlogo() {
    echo '<style type="text/css">
    h1 a {background-image: url('.get_bloginfo('template_directory').'/images/login.jpg) !important; }
    </style>';
    add_action('login_head', 'custom_loginlogo');
    Yogesh Bhade
  6. ahoque
    ahoque Guest
    Thanks. This removes the W logo. However, it still does not show my site's logo?
  7. Yogesh
    Yogesh Guest
    You have to set path of your logo image in above code.
    Yogesh Bhade
  8. ahoque
    ahoque Guest
    Thank you. I did put the path to my logo, however, it makes my logo very small and the url it puts is wordpress.org. How can I fix this?
  9. ahoque
    ahoque Guest
  10. Yogesh
    Yogesh Guest
    .login h1 a {
    background-size: auto;
    height: 110px;
    width: 320px;
    Yogesh Bhade
  11. Yogesh
    Yogesh Guest
    Use following code in functions.php to change url of your logo image in login page.
    PHP:
    add_filter'login_headerurl''w4dev_login_headerurl');
    function
    w4dev_login_headerurl()
        return
    home_url();
    If you want to change title of logo image of login page use following code in functions.php file
    PHP:
    function change_wp_login_title() {
        echo
    get_option(‘blogname’);
    add_filter(‘login_headertitle’‘change_wp_login_title’);
    It will resolve your issue.
    Yogesh Bhade
  12. ahoque
    ahoque Guest
    Hello, should I remove the intial code above and replace with the new codes you provided?
  13. Yogesh
    Yogesh Guest
    You have to keep all code that i gave you.
    Yogesh Bhade
  14. ahoque
    ahoque Guest
    Hello, unfortunately, the logo size is still small.
  15. Yogesh
    Yogesh Guest
    Hello Ahoque,
    You have to manage it's CSS in function with !important text like as following.
    h1 a {background-image: url('.get_bloginfo('template_directory').'/images/contentimg.png) !important;
    background-size: auto !important;
    height: 110px !important;
    width: 320px !important;}
    </style>';
    Yogesh Bhade
  16. ahoque
    ahoque Guest
    Thank you. It worked. How do I change the logo's alt tag from Powered by Wordpress?
  17. ahoque
    ahoque Guest
    Feature video on homepage doesn't work anymore?
    the function mentioned doesn't work any more after making the above changes?
  18. Yogesh
    Yogesh Guest
    To change title of logo (alt tag) use following code in functions.php file.
    PHP:
    function my_login_logo_url_title() {
        return
    'Your Site Name and Info';
    add_filter'login_headertitle''my_login_logo_url_title' );
    Yogesh Bhade
  19. ahoque
    ahoque Guest
    Thank you!
