Password Reset Function Not Working
Discussion in 'Subscribely v2 WordPress Theme' started by lleemills, Aug 25, 2014.
  1. lleemills
    lleemills New Member
    We have an issue with the password reset function. The password reset link contained within the email directs the user to the following URL, however there is not a password reset function present on that page. We have several users who have encountered this issue.
    http://oilrevolutiondesigns.com/wp-login.php?action=rp
  2. Pramod
    Pramod Guest
    We check here on the live subscribely v2 which work perfectly for reset password .
    http://www.neerajagarwal.net/login/
    Please have a look on the above link.
    Pramod
  3. linhnguyen
    linhnguyen Member
    Having the same issue.
    Password reset link leads to sign in and sign up page.
    Please help...
    Rewards,
  4. Pramod
    Pramod Guest
    We have got this concern, and reply you soon.
    Pramod
  5. lleemills
    Despite several email exchanges with support, the password reset function is still not working on our site and we have several impacted users. Is there a way that we can schedule a call with you so that we can show you our issue? We are extremely frustrated and considering an alternative solution.
  6. Pramod
    Pramod Guest
    We will try best from our side to solve issue.
    Your all threads Link:
    Your Website URL:
    WordPress Username:
    WordPress Password:
    Pramod Patel
  7. socialsmash
    socialsmash New Member
    Is there going to be a fix to this anytime soon? We too are having the same issue. The link directs user to the sign page, nowhere to change password ??
  8. socialsmash
    Just noticed I replied in the wrong category... but the password reset issue I'm having is on the classicraft theme. Seems like this issue is on multiple ink themes ?
  9. Pramod
    Pramod Guest
    When we launch any theme firstly we test it many times by many peoples.
    If you are facing any issues then better way is to install a fresh copy of theme after deactivating all plugins. May be possible any plugin conflict with theme.
    Pramod
  10. socialsmash
    I have installed fresh copy and deactivated all plugins. When you click on the email that is sent after password reset it directs you back to the signin page. Nothing is there to update the password ect, so user can still not login ??
  11. socialsmash
    Again sorry it looks like I am in the wrong forum so I opened a new thread for my issue in the correct forum. Thanks
