Permalink default setting
Discussion in 'GeoCraft WordPress Theme' started by per bohlin, Sep 10, 2013.
  1. per bohlin
    per bohlin New Member
    Hi
    Ive got problem whit permalink.
    I can't update in profile nothing happends.
    I've seen in the forum that I have to use default permalink to get this to work.
    I change to default but it change back to %postname% immediately.
    How do I change this permanent?
    When I change to another theme its no problem
    http://www.byggannonser.se
    /Per
    I think you are getting problem with the user profile update. If yes then
    go to the
    geocrafttheme\library\controls\dashboard\ dashboard_functions.php
    and replace "dashboard_functions.php" file with file attached.
  3. per bohlin
    Hi
    I replaced the file but I still got the same problem.
    Any other solution?
    /Per
  4. Nitesh
    Thread Link:
    Your Website URL:
    WordPress Username:
    WordPress Password:
    I will check and resolve your issue
