Personal Stories Issue
Discussion in 'Dzonia WordPress Theme' started by 1stopnonprofitshop, Nov 15, 2016.
  1. 1stopnonprofitshop
    1stopnonprofitshop Guest
    Why are my personal stories getting cut off?
    theme3.1stopnonprofitshop.com
  2. nitin
    nitin Guest
    You have mentioned a fixed height for the text, because of which it is getting chopped. To revert back the same, please paste the code given below in Custom CSS section
    .testimonial_holder .testimonial-list {
        height: auto !important;
    Hope this helps...!
    Nitin
  3. 1stopnonprofitshop
    I added this and it doesn't cut it off anymore...but when it goes to "Personal Story 2" it shows "Personal Story 1" right underneath...and then on all the other Personal Stories, the "next" and "previous" buttons are way below. Probably because the issue with Personal Story 1 being under Personal Story 2.
  4. nitin
    nitin Guest
    This time just let us do it for you.
    To fix the issue, we need access to your dashboard.
    Your Website URL:
    WordPress Username:
    Password :
    We will do it for you.
    Nitin
