Personalize templates in Compass
Discussion in 'InkThemes-Support Working Hours' started by mr_berlin, Mar 6, 2016.
  1. mr_berlin
    mr_berlin New Member
    Berlin
    Hi all.
    I've just published my first page using the contact page template in my Compass Theme. Works well, but there are two elements in this template which I need to personalize.
    Where do I find them in my theme, how do I edit them, and how can I include or exclude other elements in my contact page?
    Please advise.
    Thanks, Mark
    Hello, Mark..
    For the contact map section, you can easily put your desired address map over there and for that, you just need to follow the video given below.
    Link of the video: http://screenpresso.com/=kXvae
    For your another issue, i.e. to edit details.. so that will be done by source code customization in the theme...
  3. mr_berlin
    Berlin
    Thanks. I successfully changed the map (figured it out, before you sent the videolink, actually :).
    Source code customization is a different matter, though. Can you show me the path to open the correct document in WP, and tell me which effects (names) to look for?
    Thanks, Mark
  4. mr_berlin
    Berlin
    Why is the correct icon not showing?
    Please advise. Thanks, Mark
  5. mr_berlin
    Berlin
    Icons are not working :(
  6. priya
  7. mr_berlin
    Berlin
    Still not working. It's a little frustrating...
  8. mr_berlin
    Berlin
    This is really annoying... I have the feeling this template is not working as well as I was hoping it might. Now the nav points have been changed again and no longer work with my images, which I have already changed multiple times. What can I do!?
  9. priya
    I would like to assure that there is nothing wrong with the theme as we didn't get any issue at our end while testing your issue..
    So it would be better to send us your dashboard details at [email protected] along with this thread link so that we can figure out the issue and able to resolve that...
  10. mr_berlin
    Berlin
    thanks. It seems, the problem was resolved, after I reactivated the theme.
  11. priya
    Great...!!!
  12. mr_berlin
    Berlin
    did you receive my emails? I sent them twice (from different addresses), and got the following reply twice:
    '[email protected]' am 08.03.2016 12:40
    503 Bad sequence of commands
  13. priya
  14. mr_berlin
    Berlin
    Hi Priyanka.
    I have another request regarding social icons in my Compass theme: XING is a very popular competitor to LinkedIn in Europe. Is it possible to add a link to my XING profile? And if so, could you direct me to the correct file to make the proper additions? (Once you figure out, why my theme editor is not showing).
    Thanks, Mark
  15. priya
    Sure Mark...
    I will add your desired icon to your site and will let you know the changes whatever will be done..
