Hi, when uploading a photo, it is automatically rotated 90 degrees. This is not desired behavior. Original image: http://themotorcycledude.com/wp-content/uploads/2013/08/barstoolalum1.jpg Thanks!
Hello, There is some problem with your images. Replace image attached with your image. It will look fine. Just open problematic images in Photoshop and save them again in png format. It will resolve this issue.
There is no problem with my images. It was taken on my iphone. The solution you have provided is not acceptable. I should be able to take a photo on my iphone and use it when posting an ad. How do I open a photo in photoshop on my iphone? There are other users reporting this same problem. It is a bug either in your theme or in some third party software which you use to display images, it is not a problem with my photos.
Hello, Do one thing. Activate default WordPress theme (Twenty Ten or Twenty Eleven) In your dashboard. After that create a new post and upload your "barstoolalum1.jpg" image through your system. It will automatically rotate 90 degree.
