Pictures not showing
Discussion in 'GeoCraft WordPress Theme' started by bluepen21, May 15, 2014.
  1. bluepen21
    bluepen21 Guest
    Yesterday I was able to upload pictures to listings but today every time I have tried it seems to have uploaded the picture but I'm just getting the box with a 'x' in the corner. Is this a normal problem with the theme? Can anyone help?
    Do let us know your website link.
    Gourav Shrivastava
  3. bluepen21
    bluepen21 Guest
    It seems the XML Site Map Plugin was causing the problem. I use this plugin on all WP sites but unable to use it with this Theme. What other site map plugin would work and not cause problems with Geo? Is there a need for a sitemap plugin?
  4. Gourav
    Our theme are compatible with almost all the plugin available in WordPress.org but there are thousands of plugin available on WordPress.org and some are regularly updating and some are not updated from many years therefore it is not possible for us to check every plugin with our theme, So you can search any alternative of that plugin.
    Or
    You can also contact to plugin related support forum. They will help you.
    Gourav Shrivastava
