Hi, I recently downloaded the Pinterest "Pin It" Pro button from Phil Derkson through WordPress. On the plugin site, and other sites that use the same plugin, the social media sharing buttons are all placed horizontally next to eachother. However, on my website, they are vertical. I have contacted the plugin developers and they have suggested that it is a theme-related issue. I have attached a screenshot of my website at the top of the page, and another website at the bottom, of what I want my sharing buttons to look like. Please advise. I am using a child theme, within the Cloriato theme. www.iozzolino.com Thanks in advance.
Hello, We have checked your website and it seems that you are using WooCommerce plugin, that overrides theme default template and also break the layout. Follow the link given below, It shows you how to make theme compatible with Woocommerce plugin. http://www.inkthemes.com/how-to-make-inkthemes-compatible-with-woocommerce/04/?no-dialog Thanks & Regards Gourav Shrivastava
