Placement of Lead Capture In Sidebar
Discussion in 'Lead Capture WordPress Plugin' started by cbshanley, Mar 4, 2016.
  1. cbshanley
    cbshanley Member
    Right now the Lead Capture is sitting below other widgets on my Home page sidebar. How can I place near the top of the sidebar in between widgets?​
    Or is there a way to make it, or add it to, a widget.​
    Thanks,​
    Mark​
    Hello Mark,
    You can easily do it via widget section of the dashboard, you just need to place the LeadCapture plugin in Homepage sidebar widget field and check after that.
  3. cbshanley
    cbshanley Member
    doh.jpg I looked in the widgets and didn't see it. That's why I got in touch with you. Now I see it. Thanx.
    You're welcome..:)
