Hello! I am trying to change the background theme color and have succeeded in changing some areas using the .css coding you provided for another user; however, there are still other areas that require adaptation... All the buttons need to be changed to the teal color The quotation mark in "what our clients are saying..." testimonial section needs to be changed to the teal color The decorative lines in the footer needs to be changed to white All the font in the footer needs to be changed to white The upside down triangle in the header area needs to be changed to teal The search widget color needs to be changed as well Thank you kindly! I really do like the fact that Infoway's design is clean and simple. Cheers! Bernadette Our site - www.sac.bleauassociates.com
Sorry can I also get the .css code for the infobar link? I want to make it a darker color so it stands out. Thank You
Hello, Paste this code in Custom CSS Appearance > Theme Option > Styling Option > Custom CSS For footer widget area .footer-wrapper .footer { background: YOUR COLOR VALUE; } For footer bottom area .footer-bottom { background: YOUR COLOR VALUE; } I think by button you mean top scroll button. You can edit it through infowaytheme > images >topsroll-icon.png Thanks & Regards Nitesh Raghuwanshi
