Pls help!!!
Discussion in 'BizWay WordPress Theme' started by wilson1stop, Apr 16, 2013.
  1. wilson1stop
    wilson1stop New Member
    Can you help me?
    How to totally remove the SEARCH in menu bar?
    How to change all hyperlinks color to Orange or Blue?
    My website:
    Paste this code in Custom CSS
    .top-search {
    a {
    color: orange!important;
  3. wilson1stop
    Hi Nitesh,
    Thank for your helps, it's works.
    But Child Drop-down Menu background color was NOT so match; and I would like to put grey color as Quote background inside post, may I know what to put in style code?
    Looking forward for your answer, thank in advance.
  4. Nitesh
    Hello Wilson,
    For menu background paste this code in Custom CSS
    #menu .ddsmoothmenu li li {
    background: your color value;
    For quote background.
    I am not getting about which quote you are talking. So please share screenshot of that area. I will provide you exact css code for that.
  5. wilson1stop
    Hi Nitesh,
    Thank again for your helps, as per your requests:
    I already did research and added myself but design was not so match? Any suggestion code? Is there any Modification CSS style guidelines available for me to refer?
    May I suggest fix the Analytic code bugs which I added code through footer.php, and add a backup Theme Option Settings (with Restore options), and On/Off button for disable mobile browser theme?
    Thanks again.
  6. Gourav
    blockquote{
    background-color:grey;
