Pls help!!
Discussion in 'BizWay WordPress Theme' started by wilson1stop, May 23, 2013.
  1. wilson1stop
    wilson1stop New Member
    Hi Admins, My Site: http://wmj.my
    My Questions:
    How to add ads banner/leaderboard (align to most right-side) just beside of my top logo. eg/ http://inkthemes.com/wpthemes/blogstrendfashionblog/
    How to remove/hide [Posted by] authors in posts/pages?
    How to change {Read more} image to text-based Read more...
    How to change {Search} & {Send} image to button-based?
    How to limit 200 characters in summary posts?
    My suggestions:
    Pls enable open in new windows for Social Networks instead of same window. (self-modified)
    Pls troubleshoot the tracking code, it's not working. (self-modified)
    Pls add BACKUP & RESTORE functions for saving Theme Options.
    Possible to add Gzip functions or Minify CSS/JS functions?
    Thank you for your helps and supports, I'm very appreciated it...
    1.For your first issue
    Go to header.php present in your theme directory and replace current code
     <div class="grid_24">
          <div class="header">
            <!--Start Logo-->
            <div class="logo"> <a href="<?php echo home_url(); ?>"><img src="<?php if (inkthemes_get_option('inkthemes_logo') != '') { ?><?php echo inkthemes_get_option('inkthemes_logo'); ?><?php } else { ?><?php echo get_template_directory_uri(); ?>/images/logo.png<?php } ?>" alt="<?php bloginfo('name'); ?>" /></a></div>
              <!--End Logo-->
          </div>
        </div>
    with code given below
          <div class="grid_sub_8 sub_alpha">
            <!--Start Logo-->
              <!--End Logo-->
          </div>
          </div>
          <div class="grid_sub_16 sub_omega">
          <a href="Enter your link address"><img src="Enter your image address"/></a>
          </div>
        </div>
    Sending image for reference
    2.For your second issue
    Paste this code in Custom CSS
    .content-bar .post .post_meta .posted_by {
    3.
    Please explain your third issue little more.
    4.For your fourth issue
    Go to functions.php present in your theme directory and add the code given below
    function custom_excerpt_length( $length ) {
        return 200;
    add_filter( 'excerpt_length', 'custom_excerpt_length', 999 );
    Thanks for your all suggestions
    We will try to add these options in our future updates.
  3. wilson1stop
    Hi Gourav,
    Thank for your helpful replied, here is more info as you needed.
    No.1 it's working, but is that possible to make 5px between leaderboard ads and menu bar?
    No.2 Solved with thank.
    No.3, I preferred display button-based r text-based instead of showing image-based buttons.
    http://wmj.my/wp-content/themes/bizwaytheme/images/side-search.png
    http://wmj.my/wp-content/themes/bizwaytheme/images/read-more.png
    No.4 is working good in English characters, but NOT working in chinese characters, any ideas?
    Thank again in advance.
  4. Gourav
    .menu-container {
    margin-top: 5px;
    .content-bar .post .post_content .read_more{
    background:none;
    text-indent: 0;
    .content-bar .post .post_content .read_more:hover{
    background:none;
    text-indent: 0;
    3.For your third issue
    Go to searchform.php present in your theme directory and follow the instruction as shown in image given below
    Now,
    .searchform input[type="submit"]{
    background:none;
    text-indent: 0;
    .top-search .searchform input[type="submit"]{
    text-indent: -99999px;
    Excerpt does not count the Chinese character because they are inline, Break the line and make some spaces between the characters, It may solve your problem.
  5. wilson1stop
    Hi Gourav, Thanks for your helpful supports, it was solved.
