Dear Support, we have am urgent issue, as it seems the plugin does not save the appointments in the the section "Booked Appointments". The section remains void. Could you login to our site and check? Thanks so much for your help. Best, Michele
Hello, While translating may be you have changed any class or value text. Please replace that file with new downloaded file. Thanks & Regards Pramod
We can't because we loose all the uploaded services and slot. Could you enter the website and check? We can create a new user for you.
Hello, Please provide the following information listed below. Your thread Link: Your Website URL: WordPress Username: WordPress Password: Send this information on our email at [email protected] Thanks & Regards Pramod
Hello, I have checked and successfully booked appointment there are not any issue with appointment it works perfectly. Thanks & Regards Pramod
Dear Pramod, I see your booked appointments, but it is the only one. If I book an appointement, I can't see it in the "Booked Appointment" section.
Hello, I have checked again and find successfully booked appointment there are not any issue with appointment it works perfectly. May be on that day not available the bookings. The more you work with theme you will understand all functionality. I booked both appointment without log in. Thanks & Regards Pramod
