Plugin problems
Discussion in 'Andrina WordPress Theme' started by stewarty, Nov 28, 2012.
  1. stewarty
    stewarty New Member
    I have been running this theme without problem for a few months until this week. I started getting warnings and the site would not load properly or allow me to log into my WP account. I noticed it was mentioning a couple of plugins "jetpack and bot-tracker" which I removed from the public html folder. This allowed me to login but the site is not fixed. All the images from the top slider are now listed down the home page. When I go to theme options, just above the options is the below text can anyone advise me what this means and how to fix it? my website is www.asisevents.com.
    Many Thanks, Gareth
    Deprecated: Function ereg_replace() is deprecated in /home/asiseven/public_html/wp-content/themes/andrinatheme/functions/admin-interface.php on line 900
  2. stewarty
    stewarty New Member
    Panic over for now it appears a plugin called dynamic headers is not setup correctly or is not compatable. Either way with it deactivated problem solved for now.
    Thanks for reading,
    Gareth
  3. stewarty
    stewarty New Member
    Hi Guys I did not manage to fix the problem just move it from the front page and login. It still apears above the theme options. Can anyone tell me what it means and how to fix it.
    Gareth
  4. Gourav
    Download theme again from your members area and upload it, This will solve your issue.
