Poblem with columns on small screens
Discussion in 'ColorWay WordPress Theme' started by csksoftware, Oct 6, 2014.
  1. csksoftware
    csksoftware New Member
    When I view this website http://www.vbknl.nl/en/contact on a for example iPhone (or other small screen) the form and the text that should be below the form get mixed. (see the screenshot below)
    I use the contact form 7 plugin for the contact form and I tried three different column/shortcode plugins (WEN's Responsive Column Layout Shortcodes, Zillashortcodes and one other) but they all give the same result.
    Would you be so kind to advise on what colum plugin to use or how I can solve this problem.
    Thank you in advance!
    Best Regards,
    Jordy
  2. Yogesh
    Yogesh Guest
    Contact your plugin author.
    Yogesh Bhade
  3. csksoftware
    The Advanced WP columns works fine with this theme.
    Best Regards,
    Jordy
  4. Yogesh
    Yogesh Guest
    @media only screen and (max-width : 480px){
    input[type="text"],input[type="email"],textarea {
    width: 98%;
    height: 18px;
    It will resolve your issue.
    Yogesh Bhade
