Popular listings tabs based on rating
Discussion in 'GeoCraft WordPress Theme' started by mohi86, Nov 14, 2013.
  1. mohi86
    mohi86 Guest
    Hi, I want to use a tabbed widget that shows the most rated listings based on week/month , can you recommend any?
    Is it possible to modify popular-post-tabs plugin which is currently only sort posts based on comments, to get and show the listings based on rating?
    something like this :
