On the home page, I added a contact for in the widget section and it messed up the portfolio section. Please check it out for me. benjaminseamancounseling.com It was I also tried adding it in the testimonial section and same thing. Without the contact form the portfolio section works great. Once I add the contact form back, the portfolio section breaks. Thanks!
Hello, Maybe that plugin is conflicting with the portfolio section. You can use "contact form 7" plugin. It will work fine with the theme. Download it from the link given below. http://wordpress.org/extend/plugins/contact-form-7/
Its not a plugin. Its html for constant contact email list program. Can you help? I need to have the constant contact form on there. On another note, the portfolio section isn't important to my client so I turned it 'off' and there is a border line that stayed on the home page so you could see something was missing. How can I get rid of the horizontal border?
Hello, Paste the following code in your Custom CSS (Appearance -> Theme Options -> Styling Options -> Custom CSS) Code: .index-content .index_info { display: none; } .index-content-wrapper hr { display: none; } This will remove the Home Page Portfolio section and the border also.
Hello, To make Your Contact Form Better On Your Website You can use "formget-contact-form" plugin, which will help you to make your contact form easily and simple. Download it from the link given below. http://wordpress.org/plugins/formget-contact-form/ You just need to register on FormGet, create your form by clicking on the fields and embed the code on your website at any page, post or widget. You can easily place the contact form on every page of your website which will increase the user interaction. You will be able to manage entire communication from a single place between you and your visitor. It will be easy for you to provide support, feedback to your users. We recommend you to try this new contact form solution on your website. Hope it will meet your requirements. You can easily replace the existing contact form with this new one. Let us know your feedback
