Portfolio section with a lot of hexagons
Discussion in 'One Page Pro WordPress Theme' started by mfcbraga, Oct 3, 2016.
  1. mfcbraga
    mfcbraga New Member
    So I just finished my website and there are two changes I would like to make:
    1) In Portfolio section, is it possible to remove the All button? Or make a limit to show the galleries there? Since I have some galleries, I don't want my website to be with like 4 or 5 lines of hexagons there.
    2) In the blog section, how to make just some posts avaiable there on the homepage? Can I create some category/tag that 'filters' the posts to appear in that section?
    Thank you in advance for your help. Best regards,
    Marco
  2. Naveen
    That is possible but, you can use some sort of gallery plugin shortcode in the custom section instead of editing the post gallery.
    As per the gallery configuration, you need to add particular tag i.e. gallery on the posts to b displayed on home page. you can put this tag to your desired posts to be displayed on the home page.
    I hope you understand,
    Warm Regards!
    Naveen Kolhe
  3. mfcbraga
    mfcbraga New Member
    Sorry but I did not understood. I know how to make the posts to appear in the portfolio section, I just want to remove the All button if it's possible, or show less hexagon in All button.
    And about the second question, can you help me?
    Thank you,
    Marco
  4. Naveen
    I am afraid to say that, I was unable to locate the area in the theme...
    It would be better for us to understand your query with the help of edited screenshot.
    Naveen Kolhe
  5. mfcbraga
    mfcbraga New Member
    So this is the website, particullary the gallery section. What I want is to not show so many hexagons because it's occupying a lot of the homepage section. So if it's possible to remove the All button and just stay with the categories OR establish a limit of hexagons for the All button.
    I hope I made it clear now :)
  6. Naveen
    Thanks for sharing the screenshot,
    We can modify the theme to display a limited number of post.
    Kindly, share your WordPress admin credentials at [email protected]
    WordPress site login URL:
    WordPress admin username:
    WordPress admin password:
    We will do the needful,
    Warm Regards!
    Naveen Kolhe
