Portfolio Section
Discussion in 'Nutrition WordPress Theme' started by matthewford, Oct 20, 2016.
  1. matthewford
    matthewford Member
    We are creating a website and like the portfolio section on the home page and want to use it to show various images of our shop and products. We have been adding the images as posts and selecting the correct category as per the instructions.
    Is there a way to change it so that when someone clicks on one of the images it just opens a larger version of the image instead of re-directing to that post page?
    If this cannot be done due to theme restrictions could we just make the images non clickable instead?
    Hope you can help.
    Matthew
  2. Naveen
    Hello Matthew,
    I am afraid to say that, I was unable to locate the area in the theme...
    It would be better for us to understand your query with the help of edited screenshot.
    Naveen Kolhe
  3. matthewford
    matthewford Member
    It is the portfolio section on your Nutrition home page (see attached)
    All we want is to have the images displaying as they do in a mini slider but we do now want them clickable so that it doesn't redirect to the posts page.
    Please advise.
    Matthew
  4. Naveen
    Hello Matthew,
    That's actually the post thumbnail image slider of your blog posts so it is not possible to redirect them anywhere.
    However, you can use some other slider plugin there to achieve your needs.
    Warm Regards!
    Naveen Kolhe
  5. matthewford
    matthewford Member
    Ok, can you advise on a suitable plugin? What we are wanting to achieve is attached in this screenshot, it looks so nice already so could we just not make the post thumbnail image slider non clickable?
    Matthew
  6. Naveen
    I am sorry, no such plugin is available which can work in the way you want.
    That needs to be modified from the source code.
    I hope you understand.
    Warm Regards!
    Naveen Kolhe
