Possible help with a widget issue
Discussion in 'GeoCraft WordPress Theme' started by erjdavis, Feb 14, 2013.
  1. erjdavis
    erjdavis Member
    Philadelphia, PA
    I am using a widget to create a form on my site. For some reason because of the coding, the form does not show up on the home page on the sidebar...but does on the sidebar on all other pages. I tried playing around with the code and can not figure it out. Was hoping maybe you guys have a possible solution or could guide me in the right direction?
    Home page where it does not work - http://bucksmontreviews.com
    Lisiting Page where it does work - http://bucksmontreviews.com/all-listing/
    Thanks for any help you can provide!
    Go to
    Appearance > Widget
    Drag text widgets and add form short code and drop them in the Home Page Widget Area, It will automatically display at your home page sidebar.
  3. erjdavis
    erjdavis Member
    Philadelphia, PA
    Hi Gourav,
    I tried this but it still does not appear on the home page. Any thoughts?
  4. Gourav
    Thread Link:
    Your Website URL:
    WordPress Username:
    WordPress Password:
  5. aliounn
    aliounn Member
    hi erjdavis,
    Your website looks good.
    how did you add the links in the footer as shown in the attached file ?
    What widget did you use for social icons ?
    Thank you
  6. erjdavis
    erjdavis Member
    Philadelphia, PA
    Thanks, Aliounn.
    The footer text I edited the footer.php file. It is all custom coded.
    For the social link, that is also custom coded using. Using the text widget I placed some basic HTML. Here is the code and attached images and just upload the images to your site and replace the links to fit your needs. Hope that helps!
    HTML:
    <a href="yoursite" target="_blank"><img src="http://bucksmontreviews.com/images/facebook.png" border="0"></a>
    <a href="yoursite" target="_blank"><img src="http://bucksmontreviews.com/images/twitter.png" border="0"></a>
    <a href="yoursite" target="_blank"><img src="http://bucksmontreviews.com/images/google-plus.png" border="0"></a>
    <a href="yoursite" target="_blank"><img src="http://bucksmontreviews.com/images/linkedin.png" border="0"></a>
  7. aliounn
    aliounn Member
