POST NOT SHOWING UP ON MY WEBSITE
Discussion in 'ColorWay WordPress Theme' started by joblak1, May 22, 2014.
  1. joblak1
    joblak1 Guest
    ello, I created a new post and published it but the only thing I can view on the website it the title of the post-not the content. Here is the page link
    Attaching a screen shot of what the post looks like when I click on Edit post
    The post is not in draft form or anything..... Any ideas what the cause is and how I can fix it?
    Thanks!
    I think it is the plugin which is creating problem.
    Deactivate all plugins to see if this resolves the problem? If this works, re-activate the plugins one by one until you find the problematic plugin(s).
    Nitesh Raghuwanshi
  3. joblak1
    joblak1 Guest
    Nitesh- thanks. Can you tell me if deactivating the plugins will erase the settings they already have in place? If it is a plugin, how would I resolve the problem if I still wish to use that plugin?
  4. Nitesh
    Deactivate plugins and then again activate them. Just leave problematic plugin deactive. Plugins will regain there old settings.
    I think social media plugin is creating this problem. Deactivate them first.
    There are multiple plugins available at the WordPress.org. So you can search for alternate.
    Nitesh Raghuwanshi
  5. joblak1
    joblak1 Guest
    it worked it was a plugin from jvzoo that was the culprit
