Post page width
Discussion in 'RoadFighter WordPress Theme' started by smarta, Sep 8, 2015.
  1. smarta
    smarta Member
    is there a way to make post full width pages?
    You can make your post full width, you just all have to make these changes as shown in the screenshots given below.
    Inkthemes.com
  3. smarta
    smarta Member
    Sorry to learn, above solution didn't work for you..
    Here I am providing you a video, please follow the steps as mentioned in the video given below.
    Link of the video: http://screenpresso.com/=8s19c
    Note: You just need to follow two steps, first one is to comment-out the sidebar section and second will be to replace grid_17 with grid_24 in "single.php" file as I have done in above video.
    As I have told you in my earlier post that I am using wp-editor plugin to edit the file.
    Hope you will find it helpful.
  5. smarta
    smarta Member
    that worked but i had to delete the line 78 part as commenting out did not work
  6. priya
    I really don't have idea why commenting out didn't work at your end because it works perfectly at our side..
    But it's good to hear that deleting that section worked in your theme to achieve your destination.
