Post Slider At Home Page
Discussion in 'ReThink WordPress Theme' started by saahilk2000, Feb 10, 2015.
  1. saahilk2000
    saahilk2000 New Member
    How can i change the slider to display recent posts or posts that I selected with the post heading and excerpt? Right now it just gives an option to display pictures.
  2. saahilk2000
    Bhai log ... was really hoping for better support ....
    1. how do i change the slider to appear only on the 1st page and not all?
    2. Can i change the slider to show featured posts? or post that i manually select?
    3. How do I move the search widget to the header area? Where you guys have the amazon ad placed.
  3. Pramod
    Pramod Guest
    Hello !
    You have to put manually images and links on slider from theme option related to latest post.
    Slider by default appears only on first page.
    To move search widget area you have to use code in header.php file for widget area.
    Pramod
  4. saahilk2000
    Hello Pramod,
    Thanks for replying.
    1. Can you please guide me through adding the search widget to the header.php file?
    2. Slider is appearing on all pages. Please check my website at the link below. Its there on all the pages, how do i change it to appear only on 1st page?
    http://vargiskhan.com/log/
    Vargis
  5. Pramod
    Pramod Guest
    Hello Vargis !
    To add search bar in header you have two option one is to use widget code and another is use <?php get_search_form(); ?> this will show automatically search bar.
    We are not getting slider on all pages please provide at least two page links which have slider.
    Pramod
  6. saahilk2000
    Hello Pramod,
    1. Where do I get the code for search widget which is currently posted in sidebar on the website?
    2. When you open the website, the slider is on page http://vargiskhan.com/log/ and then it is also there on http://vargiskhan.com/log/page/2. Then it just keeps appearing on each page as I change the page #s.
  7. Pramod
    Pramod Guest
    Hello !
    1)You can find code in sidebar.php
    2)Still i am not getting any slider on link which you provided.
    Pramod
